Maximum PW at cranking
Postby pnanassy on Mon Dec 21, 2009 7:06 am
what is the maximum allowed fuel injection Pulse Width at cranking?
I tried to go over 32ms but looks like something in the software overflows and it displays some weird minus values.
Car starts only if i pump the throttle while cranking,this gives me about 40ms with the accel enrichment.
Car idles with 5-7 ms,2226cm3,5cyl,200cm3/min injectors
Peter
pnanassy
Re: Maximum PW at cranking
Postby pnanassy on Fri Dec 25, 2009 7:59 pm
i2 datalog shows reasonable values (39-52ms),so its only the Motec ECU Manager software that has the problem?!
pnanassy
Postby bing on Thu Dec 31, 2009 11:49 am
check "Post Start" option i think under fuel.
Also tune injection timing will help.
Post cal file see if we can help.
bing
Users browsing this forum: Google [Bot] and 21 guests
