E888 wiring
E888 wiring
Postby Takumi on Fri Aug 01, 2008 6:15 am
I an using 22 gague wire for the EGT's and CAN.
What is the max size wire i can use for the power and ground? this is a AMP connector.
im using pin A17 power, A10,A11 for ground
Should I use A17, B8, B9 20gague and splice to a 12gague?
98 240sx 25.1 240sx | VQ35DETT 2000hp | Twin Garrett GT47R | G-force GF2000 | Motec M800/SDL/E888/PDM 16/SLM |
Takumi
Re: E888 wiring
Postby DarrenR on Fri Aug 01, 2008 10:17 am
It depends what you are driving with the outputs, the unit itself uses very little power. If you are using all outputs to their maximum then what you have suggested would be good. But if not using any outputs, a single 20 gauge for +12v and GND would be fine.
You can fit up to 16 gauge Tefzel wire into the AMP connector no problem.
Darren Reynolds
DarrenR
Re: E888 wiring
Postby Takumi on Sat Aug 02, 2008 12:03 am
thanks
Takumi
