Problem opening log files.
Postby antopizzuto on Wed Jul 22, 2009 6:07 pm
Hi, I'm a new user of Motec i2.
I downloaded Pro and Standard version to try them but I have the some problems with both software.
I can't open log files (except the "sample data" contained into the program)!!
I have some data files (.ld) coming out from a simulation software but when I try to open them the dialogue box tells me that "the directory contains no log files".
Why?
The demo versions have some limitations?
Please help me.
antopizzuto
Re: Problem opening log files.
Postby JamieA on Thu Jul 23, 2009 11:56 am
Unfortunately, due to some other data logging manufacturers deciding to use i2 as the analysis tool for their applications, we have had to restrict the use of i2 with non motec hardware derived data.
So because of this, unless the data is created using MoTeC hardware, you cannot use i2 to analyse it. This includes simulation software.
We are about to release a new MoTeC applicaiton programmers interface for i2 pro. This will, for an annual subscription, allow you to effectively open and export any files using i2, after massaging them in the API.
regards
-Jamie
JamieA
