GPS Date wrong by 20 years
Postby AFK88L on Fri May 15, 2026 1:19 pm
I recently noticed an issue with my C127 dash display showing the wrong date.
I believe I've worked out the root cause (and a workaround), but just wondering if a firmware update is possible that could fix this issue?
It's been working correctly for years, but some time in the past 6-12 months (hadn't been paying that much attention) the date started to display incorrectly.
Setup is a C127 Race Display Kit that I purchased back in Aug 2016. This came with a 10Hz GPS unit (L10).
I've been using my own custom Display Creator design, with no changes since 2021, and it had always been correct until now. I output the DOW Day/Month and Time (24hr) to the bottom section of the display, as below.
This was taken on "Tue 28/04" but the display was showing "Tue 12/09".
Thinking a Display Creator issue, the next day I updated the display to output the full date (also upgraded to Dash Manager 6.51.12.0 and Display Creator 6.5.1.0205 at the same time to see if there was a fix already).
So the full date showed as 13/09/2006 instead of 29/04/2026.
I finally realised I should actually monitor the GPS Date channel value and found that's where the issue is. The GPS unit is outputting the wrong date?
It was outputting a value of 130906 (DDMMYY).
I noticed something when I did a date calc between the two dates.
1024 weeks looked suspect.
I have since learned GPS systems use a week count plus time-of-week value, since a certain date.
So it looks like my L10 GPS device might only be using a 10-bit value for the weeks (max value 1023) which means there's a date rollover issue every 1024 weeks (since some internal hardcoded start date), I think?
My workaround has been to create a constant channel with a value of 7168 and use this as the "Date Offset (Days)" in the Real Time Clock config of Dash Manager.
That works, but wondering if a firmware update is possible to ensure the GPS Date channel value is correct in the first place?
AFK88L
Re: GPS Date wrong by 20 years
Postby Stephen Dean on Mon May 18, 2026 6:33 pm
Try this resolution.
Return to GPS Information
Users browsing this forum: No registered users and 0 guests
