electric wastegate with M800
Postby MyRaw on Wed Oct 16, 2024 6:40 am
Good morning everyone!
I wanted to know if anyone has managed to use an electric wastegate with M800??
MyRaw
Re: electric wastegate with M800
Postby Stephen Dean on Wed Oct 16, 2024 9:22 am
Using the Turbosmart "Black Box" controller for the EGate, and sending a PWM signal into the controller from the M800 with give you position control of the gate, but with no real feedback.
You could possibly build some aim tables using the Aux Tables, but this would be something that you would need to develop yourself.
Postby cotje on Thu Oct 17, 2024 6:55 am
YES! check my post: https://forum.motec.com.au/viewtopic.php?f=11&t=5661&sid=3651717759cf09d02bc4214d8333f48b&sid=2dff934a576d1b997770d1a4f7583c1e#p25749
Did this for the eALV with blackbox and planning to use the second output of the blackbox for the eWastegate. Gives very nice and precise control of the valve opening (with Aux-table as stated by Stephen). I even linked it to another table to be able to enable/disable the behavior (Boost-setting 1 > no eALV, Boost2/3/4 > with eALV).
Beware, these valves need serious power! In my case, controlled by a Motec PDM.
cotje
