Speed by CAN from dash
Postby gtihk on Sun Mar 24, 2024 12:07 pm
Hi guys,
I have four wheel speed sensors connected to a SDL3 and the speeds are sent via CAN to a M142.
In M1 tune, could someone advise as how I should work out the scaling for speeds received via CAN please?
I have tyre circumference 1.773m. Thanks!
gtihk
Re: Speed by CAN from dash
Postby Stephen Dean on Mon Mar 25, 2024 2:55 pm
Use a scale of 1566.711 and a Sensor Teeth count of 100, the dash should be transmitting the wheel speeds with a resolution of 0.1km/h.
Postby gtihk on Tue Apr 02, 2024 12:26 pm
If the wheel circumference is changed. How do I calculate the new scaling required, or is it not necessary because it has been accounted for in the dash?
Could you explain how the value of 1566.711 is actually calculated please?
gtihk
Postby Stephen Dean on Tue Apr 02, 2024 4:45 pm
In an excel spreadsheet, the formula is as follows.
Base Resolution (Dash)/(Base Resolution (Dash) * 10 * Wheel Circumference (m) (M1) * 3.6/1000) * Sample Teeth (M1)
So, for your case it is 0.1/(0.1*10*1.773*3.6/1000)*100 = 1566.711
