M130 GPLite map switch
Postby Alwayslearning on Mon Jan 01, 2024 3:45 pm
Anyone familiar with the GPLite ECU? I'm wondering if I can use an ethanol content sensor on pin B6 which is pre-assigned as Map Switch?
Alwayslearning
Re: M130 GPLite map switch
Postby Stephen Dean on Tue Jan 02, 2024 9:34 am
Pin B6 on the M130 is an Analogue Temperature (AT4) input, this is not the type of input that will recognise the digital signal from the Ethenaol Content sensor.
Postby greenamex2 on Tue Jan 02, 2024 8:06 pm
You would need to use a "UDIG" pin, so B8/9/10/11/14
greenamex2
