Custom square wave output needed.
Postby DynoDom on Wed Nov 08, 2023 11:55 pm
Hello
Is it possible to generate a custom (50/50, 12volt peak, 0-225 hz = 0-100 km/h) square wave signal output in either M150, C1812, PDM30?
This is intended as the vehicle speed signal into an electric assisted power steering.
Wheel speed sensor Inputs and GPS speed are already present on the CANbus.
Thank you in advance.
D
DynoDom
Re: Custom square wave output needed.
Postby NathanB on Thu Nov 09, 2023 9:58 am
Hi Dom,
You will use one of the aux outputs on the C1812 for variable frequency:
Frequency control C1812.png (148.83 KiB) Viewed 6171 times
Please note that the aux output will be low side, so you will need to add a pullup to 12V to achieve your square wave.
Postby DynoDom on Fri Nov 10, 2023 2:38 am
Thank you very much Nathan. PM sent.
DynoDom
Postby DynoDom on Sat Nov 11, 2023 4:25 am
Hello again with one follow up question:
The manufacturer of the steering unit pointed out that frequency should not exceed 225 Hz.
Our custom Signal ends at 1000Hz.
Do you see a way to freeze the 225Hz at 100 km/h and above?
Thanks in advance,
Dom
DynoDom
Postby David Ferguson on Sat Nov 11, 2023 9:22 am
A couple of solutions:
- Don't go faster than 225 km/h
- Don't send Ground Speed -- but instead send the output from a table with (ground speed as the input) that has three data points, 0=0, 225=225, and 1000=225.
Postby DynoDom on Sat Nov 11, 2023 9:34 am
Hi David
It is 225hz at 100 km/h.
I try to achieve the table solution you mentioned.
Thank you,
Dom
DynoDom
Postby DynoDom on Mon Nov 13, 2023 11:21 pm
Hello again
Unfortunately, due to my inability, I failed to create the above mentioned table to freeze the frequency at 225hz when speed is > 100 km/h.
Could you perhaps show a sample of how it is done correctly?
Many thanks in advance.
D
DynoDom
Postby David Ferguson on Tue Nov 14, 2023 6:17 am
Here is what a 2D table would look like that takes Ground Speed and produced the channel "GP Speed 1 (Lge)"
Speed Cap Table
Speed Cap table.JPG (36.7 KiB) Viewed 5984 times
And here is how your Aux Output would be setup using the "GP Speed 1 (Lge)" channel:
Aux Output Config
Auix Output Config.JPG (36.5 KiB) Viewed 5984 times
Postby DynoDom on Tue Nov 14, 2023 11:39 pm
Thank you David.
DynoDom
Postby DynoDom on Thu Nov 16, 2023 3:04 am
Good day
The Steering works as intended, thanks to your great support. Thank you very much indeed!
@MoTec
One small Bug in the "monitor dash" is that Aux3 output does not show values, even though the function works.
I just thought to let you know.
Best regards,
D
DynoDom
Users browsing this forum: Majestic-12 [Bot] and 17 guests
