Ford Coil Characterisation
Postby nobletech on Sat Aug 19, 2023 9:18 am
where can I find the data for the below coils for an M150 ECU?
I have the car running on an M880 now, I am just upgrading to an M150
Motorcraft DG-513
FORD OE2M2Z-12029-AC
MOPAR BRAND1AMIC00027
NISSAN OE26020130
nobletech
Re: Ford Coil Characterisation
Postby Stephen Dean on Mon Aug 21, 2023 10:22 am
I do not have a specific calibration for those coils, using any of the supplied part numbers.
Where did you get th dwell information currently in the M800? If this is calibrated data, then it can also be used in the M1.
Postby nobletech on Wed Sep 06, 2023 11:55 am
Thanks for the reply, however, I've already sent it to Motec east for characterization.
On a similar note, can they characterize a throttle body, or maybe you can supply the data for a Mazda v6 TB
part# 3M4E-CH
Mazda # FSD7-13-650A
nobletech
Postby Stephen Dean on Wed Sep 06, 2023 12:52 pm
I have no matches for those part numbers, MoTeC USA will be able to organise for the throttle to be calibrated.
Return to M1 Build
