C12X Transmit Messages
Postby 01-0041 on Sun Jul 30, 2023 5:20 am
Hello all,
I thought I had a handle on this, but I'm stuck.
Is there a way in import a DBC file that keeps all of the transmit functions without using DC?
Thank you!
01-0041
Re: C12X Transmit Messages
Postby SOReilly on Mon Jul 31, 2023 9:48 am
Currently the import DBC function will only create receive CAN sections.
This has been marked as an item to be reviewed in future.
Regards,
Scott
SOReilly
Postby hamer on Sat Aug 05, 2023 7:05 am
I'd love to see this feature as well.
Right now I have to import the DBC, screen shot all the settings of each channel under "received channels", change to transmit, then manually re-enter those settings.
It would also be great to have the settings for transmit be a little more clear cut, with starting bit, length, etc, so you can actually see what you're setting up a little more clearly.
hamer
