Boost Control
Boost Control
Postby insomnia on Tue Apr 21, 2009 9:05 am
hi together,
i search the method to use my M800 like an AMS 1000 Boost Controler...
I have a Gear Position Sensor and i want to adjust a different turbo boost for
the different gear...if possible i want to increase or decrease the boost with 2
switch...if anyone as a idea....i dont know the right way to do this...
Thanks for advance.
Francois
insomnia
Re: Boost Control
Postby OmarK on Fri Apr 24, 2009 2:32 pm
Using ECU Manager you can change your x-axis and y-axis in a boost compensation table to the gear channel and rpm channel perhaps and then set your boost trim % quite easily.
OmarK
Re: Boost Control
Postby insomnia on Sat Apr 25, 2009 8:54 am
thank you for the answer!
i want to control 2 solenoide for increase or decrease the boost pressure....
i want different boost pressure with the different gear.....
insomnia
