Shutdown on input
Shutdown on input
Postby HMeier on Sat Feb 11, 2023 1:00 am
i have a C187 display logger. I want to shutdown itselfs and wake up, when a analog or digital input value is incoming (like clamp 15). Voltage is alway available.
Is this possible? And how configure it.
Best regards
HMeier
Re: Shutdown on input
Postby Stephen Dean on Mon Feb 13, 2023 8:49 am
Is there a reason that you want it to do this? They are designed to be switched on/off through the main power, doing what you described essentially requires the Dash to go into a sleep mode, which isn't supported.
