Help With Gear Indicator Not Working On C125
Postby benntrevv on Fri Feb 10, 2023 8:04 am
Hey Guys,
So I'm running the c125 dash on my 2019 yamaha r6 race bike with a yamaha racing YEC ecu. Finally got the loom built & installed, uploaded the config and display creator files to the dash and got everything working except the gear indicator. I can go up and down the gearbox and the dash just displays a "N"
I'm not clued up at all about the can etc.. but my friend who built the loom plugged it in and could see that when he moves the gear lever up and down the gears he was getting a can reading etc.. so its reading, it's just not relaying it to the dash if that makes sense.
I've attached my dash manager file and display creator file so feel free to have a look and see if I've missed or done anything incorrect
Ben
DASH COMPLETE FINAL Modified.c125v64
(1.35 MiB) Downloaded 405 times
Dash Complete Final Modified.dcproj
(2.87 MiB) Downloaded 377 times
benntrevv
Re: Help With Gear Indicator Not Working On C125
Postby Stephen Dean on Fri Feb 10, 2023 11:24 am
Hi Ben,
Who did the locked CAN receive templates? If the YEC ECU is transmitting a Gear value over CAN, but the Dash is not generating the value on the display, it sounds like there may be an issue with the receive template.
