Motec C127 unable to flash
Postby yanahivalencia on Thu Oct 13, 2022 1:25 pm
Hi Everyone,
I have one Motec C127 that has been unable to flash. We've tried two different harnesses (both work with other Motecs), 2 different computers, 2 different ethernet adapters and also manually tried setting the IP per the help instructions
The Motec does not show up when you look for devices,
would someone have been had some similar issue? or would someone could have any recommendation that I could try?
Thank you!
yanahivalencia
Re: Motec C127 unable to flash
Postby David Ferguson on Thu Oct 13, 2022 2:19 pm
I've had that issue when I was using the wrong Dash Manager by mistake.
I think there was also a Windows update issue (they replaced some MoTeC-required networking component) where re-installing the Dash Manager (with repair option) worked to restore operations, so you might give that a try. Forum thread on this:
viewtopic.php?f=53&t=4748
Also, make sure IPV6 is enabled, this thread is about that issue:
viewtopic.php?f=70&t=4445&p=20157&hilit=dash+ethernet+install#p20157
Postby Stephen Dean on Thu Oct 13, 2022 2:27 pm
The Latest Windows Updates have been breaking the internal links between the Managers and the mDNS system that MoTeC Discovery uses to get the IPv6 addressing, by reinstalling the dash Manager (or running the Help | Repair function in M1 Tune) these links are recreated and allow for the correct operation of the Managers.
Return to MoTeC PC Comms
Users browsing this forum: No registered users and 0 guests
