Warning Light
Warning Light
Postby Exigeman on Wed Aug 31, 2022 11:38 am
Hi
I Have an SPA Dash in the Exige and that has a Lamp that can be used as a MIL. I previously used it with the Honda K pro as a knock warning using a relay to drive it.
What is the best way with the M130 ? - I have thought to use the same relay and drive it with a HB output .. but could I just use the HB to drive the lamp to make the wiring simpler ?
Exigeman
Re: Warning Light
Postby Stephen Dean on Wed Aug 31, 2022 2:25 pm
I would configure the Warning Light Resource to be triggered by the Knock Warning system, and then wire the light to the resource selected. You should be able to drive the light directly from the M1 with out using the relay.
