I would like to set a specific function for a HBx output,
similar to what could be done in Aux Output Function in M84
(for instance "4 - Tacho signal or 107 - Gear Change Light" or whatever.....)
How do I do that in M150?
David Ferguson wrote:That will be a simple change if you create a custom firmware package for the customer. Or perhaps there is already a partner package with this feature.
Is there a reason the same Tachometer output signal can't be used for both purposes?
SDean wrote:If you have GPR, why would you use an external gear cut system?
Users browsing this forum: Google [Bot] and 12 guests
