David Ferguson wrote:Yes, there are various options to export a logged data file. You can send just a certain range of data, as well as just channels on the current worksheet.
David Ferguson wrote:I'm sorry, I thought the "visable data" option only exported the the channels currently shown on the worksheet. I just did a test and that's not the case.
David Ferguson wrote:Of course, you can change the logging from either a Dash Logger, or ECU = for future recorded data, I was thinking you wanted to share some existing data.
adrian wrote:To export only certain channels, add them to a T/D graph and then right click on the graph and click 'Export Data'. Under 'Source Channels' select 'Visible Channels' and your exported file will only have the channels in you T/D graph.
