Dash C125 can error
Re: Dash C125 can error
Postby Stephen Dean on Wed Mar 16, 2022 9:30 am
Are you trying to use Display Creator to build a custom configuration?
Postby Stephen Dean on Thu Mar 17, 2022 8:43 am
If you do not have the Display Creator enable in your Display, then you will not be able to load a Display Creator configuration into the Display.
Postby Stephen Dean on Thu Mar 31, 2022 8:52 am
Looking at the serial number details for that Dash, you do not have Display Creator enabled on that Dash so you will not be able to use the Display Creator functions with it.
Postby David Ferguson on Fri Apr 01, 2022 8:12 am
Contact your MoTeC dealer, give him your C125 serial number and order the Display Creator option. When you get back an enable code use Dash Manager->Online->Dash Options (Upgrades), and enter the enable code. Then try the steps you used above.
Postby David Ferguson on Sat Apr 02, 2022 6:38 am
Any MoTeC dealer (in your country) can sell you the Display Creator upgrade. The Dash does not need to be removed, the upgrade is done via the enable code using Dash Manager.
Return to Display Creator
