Thanks.
Chris Wilson wrote:Thanks for the excellent explanations and illustration. I assume people capable of this multi dimensional mapping are limited here in the UK? I would like the map to be pretty optimal, and hope to have the engine (RB26 Nissan) mapped on a proper engine dyno. Having spent a lot of time and money on the thing I'd hate to have it compromised by poor part throttle running, although, as a track car, maybe the benefits will be less noticeable?
gring wrote:The challenge with ITB throttles and turbocharging is that there will be a difference in airflow at different throttle positions but the same boost pressure. This means that the air fuel ratio will change if not accounted for. There are several different strategies that can be employed and will depend on the particular engine. You need get a stable MAP signal using a manifold chamber box to be able to use MAP for any type of correction. I like to use a main fuel table based on TPS and RPM and a secondary table based on MAP and RPM or TPS and MAP to account for the VE differences at different throttle position. I still retain the double pressure double fuel MAP compensation table. I map the engine on the lowest boost setting and get the air fuel ratio correct. Then any changes required are done in the seconday fuel table.
YMMV.
