area under the curve
Postby Merlin on Thu Jan 15, 2009 6:34 pm
Hi guys
is it possiable In I2 to do a maths function to calculate the area under the curve
example
I use a adl as a logger on my dyno...It loggs the output of a load cell then with a maths function I get my readings
I would like to able calculate the area under this curve....from 2 points I asign
John P
Merlin
Re: area under the curve
Postby ElectronSpeed on Tue Jan 27, 2009 3:13 am
Another word for area under the curve is integrate. It is one of the functions in the "math expression editor". So, create a channel that integrates your load cell output. Add this to your display. Use the D key and space bar to put the two cursors at the points you want and the "area under the curve" will be displayed next to triangle in a box next to the new channels name.
Eric Schieb
Electron Speed
ElectronSpeed
