SLM test fuction
SLM test fuction
Postby Merlin on Wed Jan 07, 2009 5:44 pm
Hi guys
I have a SLM connected to an M800
Is there a Test function.. so I can confirm I have this wired and configured correctly???
I do have an ADL ( early model) in the car.. Am I better connecting the SLM to it??
John P
Merlin
Re: SLM test fuction
Postby OmarK on Thu Jan 08, 2009 1:18 pm
There is no "Test Function" in the M800 for the SLM. You could simply set the rev limit or shift points to a low rpm value to check your wiring and configuration are correct.
The other option is to use your ADL, to set this up I will refer you to the document at the bottom of the following thread.
http://www.motec.com.au/forum/viewtopic.php?f=14&t=45
This document outlines the method and configuration details required to connect an SLM (Shift
Light Module) to an ADL, ie: ADL4 or ADL8. This method will not offer the same level of functionality
as the ADL2 or ACL and SLM, but will allow you to configure a set of Up Shift Lights (simple or
gear dependant) and a Warning Light.
OmarK
Return to SLM
