croosing problem when back off throttle goes lean logs m2r
Postby imi on Mon Sep 14, 2015 1:23 am
when croosing and i lightly back off gas the afr goes lean for a split sec and car starts hopping lol
i have logs below i have played with acell enrich and the clamp settings but cant seem to sort it
i will upload the file as well
https://www.dropbox.com/s/vgk2mbzqvbbe8 ... 2.T62?dl=0
most resent log
https://www.dropbox.com/s/r6rkub9i6imyz ... T.LOG?dl=0
https://www.dropbox.com/s/e5m6m47lrxxac ... _.ldx?dl=0
https://www.dropbox.com/s/4sn4kg4a4qco6 ... S.ldx?dl=0
imi
Re: croosing problem when back off throttle goes lean logs m
Postby AdamW on Tue Sep 15, 2015 12:11 pm
I only looked at the top log file but it appears there is something wrong with your lambda instrument, ignoring the odd spike it really only varies between 1.0 & 1.1 lambda so I doubt that reflects reality. You need to fix that before you base any tuning decisions on it.
The jerking effect on lift off/overrun is generally too much ignition advance.
Motorsport Electronics Ltd.
AdamW
Postby imi on Mon Oct 19, 2015 7:04 am
Thanks for reply only just recived
But yes you are correct it was related to timing to advanced thanks again
I have reduced it but upon start up i do get a lean spot on little throttle trys to cut out i will mess again and record the results and be back
imi
Postby imi on Fri Feb 05, 2016 11:18 am
This issue was sorted with fuel adjustments and the main problem was the timing as advised above
imi
Users browsing this forum: Majestic-12 [Bot] and 17 guests
