ACL - C127
ACL - C127
Postby Annakier on Sat Sep 12, 2015 7:07 pm
Will my C127 work if I use the C125 template.
Annakier
Re: ACL - C127
Postby adrian on Mon Sep 14, 2015 11:32 am
At the moment the C127 cannot be setup through the ACL config, this functionality will be added in a future software release.
Unfortunately I can't confirm a release date for this update. The best thing to do is create a standard C127 config and setup CAN templates to send/receive any channels you need between the two devices.
Re: ACL - C127
Postby Annakier on Thu May 19, 2016 1:49 pm
Any news on compatibility between these two
Annakier
Re: ACL - C127
Postby adrian on Fri May 20, 2016 10:37 am
We are now no longer developing the software for non-colour dashes/loggers, ie ACL, ADL3, SDL3 or CDL3 (and anything older). Support (and sales of the CDL3) will continue as normal for the foreseeable future.
There are two options on setting up the ACL and C127. If you have Display Creator enabled in the C127 you can use the DC setup in ACL Manager to create a DBC file that you can load into the C127 or you can simply CAN the channels you require across to the C127 and configure it as a stand alone device.
Return to ACL and VIM
