evo x m800pnp RS/GSR difference
Postby tracer on Mon Aug 10, 2015 12:35 am
In motec docs it's usually mentioned that: 'NOTE: It is essential to specify at time of ordering if you require an RS or GSR version'.
What is the difference between them?
Will it be possible to use existing m800 pnp(GSR version) on an Evo X RS (group n4)?
tracer
Re: evo x m800pnp RS/GSR difference
Postby Scott@FP on Mon Aug 10, 2015 6:22 am
Dual shaft trans vs. manual trans.
Postby SprinterTRD on Mon Aug 10, 2015 12:04 pm
If you have the 13014 version of the EVOX ECU, it will do both GSR & RS.
Return to M800 Plug-In ECUs
