SDL1 - DIG IN as a switched input
Postby bazeng on Mon Nov 17, 2014 2:21 pm
Hi Guys,
How can I use a DIG IN as a switched input?
Can I gnd the pin to activate?
I want to assign user alarm 1 to it which will activate an ouput to the ECU pending specific conditions.
Example:
DIG IN 1 = gnd
EGT = x
FP = x
OIL pressure = x
RPM = x
If all above requirements met, activate AUX output x (to ECU). ECU then requires:
AFR = x
AIR TEMP = x
activate OUTPUT -> x, increase RPM limit, increase boost, retard ign timing.
Advice appreciated.
bazeng
Re: SDL1 - DIG IN as a switched input
Postby AdamW on Mon Nov 17, 2014 8:14 pm
The Dig input can be either grounded to activate or connected to 12v to activate. Normally the ground option is the easiest.
Set your Dig input to a channel such as GP on/off, then under calibration you set it for either high or low polarity.
For the other logic I would probably set it up to use a mixture of user conditions and the alarm feature to activate your aux out. (alarm function alone only allows 4 comparisons so I would combine two into a user condition to get around that limitation).
Motorsport Electronics Ltd.
AdamW
Return to ADL, ADL2 and SDL
