SprinterTRD wrote:"Some info provided inside of M1 Tune with "F1"
"As you can see, the pressure resource is not defined."
You need to keep on reading further down in the paragrap or Click on the tree under Boost and you will see "Pressure". F1 here and your question will be answered.
There is a lot of information on each item in the resourse tree and you need to read all of it!
