Using Digital and Speed Inputs for Var Resistance Sensors
Postby Herrubermensch on Sun Jun 16, 2013 12:37 am
I have a CDL3 dash with the 12 I/O and logging options enabled. I currently am using two digital inputs and two speed inputs for switches: next line, previous line, mode and alarm cancel. But I am about to hookup a CAN-based keypad to control these switches, which will free up the related digital and speed inputs. I would like to use those digital and speed inputs either for two-wire variable resistance sensors (AIT and fuel level) or three-wire analogue voltage sensors (fuel pressure), as I already have used up the two analogue temp sensors inputs and all four variable voltage inputs for other sensors. Is this possible with some combination of pull-up and pull down resistors or do I need a more complex conversion circuit? Is this game worth the candle? Any assistance would be appreciated.
--Peter
Herrubermensch
Re: Using Digital and Speed Inputs for Var Resistance Sensors
Postby Herrubermensch on Sun Jun 16, 2013 9:58 pm
For the benefit of other readers, I have learned that this would require a micro controller and programming and is not, as I suspected, a worthwhile endeavor. It has been suggested that instead I should use a 0-5 volt to CAN converter for expanding the inputs on a CDL3. I am currently exploring that option and will report back if it works.
--Peter
Herrubermensch
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 0 guests
