M800 for 2 rotor setup is only able.to use 4 inj drivers
Postby Fast20b on Fri Mar 29, 2013 3:35 am
Is there any way to use all 8 inj drivers on the 2 rotor setup. Once you choose 2 rotor setup it only let's you use 4 inj drivers only. Are there any options for using all 8?. Can Motec do anything for this? We bought the m 800 thinking that we would have access to all drivers.
Fast20b
Re: M800 for 2 rotor setup is only able.to use 4 inj drivers
Postby 20B on Fri Mar 29, 2013 12:30 pm
Yes pretty sure you can run 4 pairs of 2 would solve your problem. , don't think you can drive all 8 sequentially.
Mazda 1993 RX7
20B N/A engine
20B
Postby Fast20b on Fri Mar 29, 2013 2:20 pm
Low impedance injectors need one driver for each one.
Fast20b
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
