Ref Sync Issue
Ref Sync Issue
Postby insomnia on Sat Oct 01, 2011 10:55 am
Hi guys,
i have a strange issue with a 4 cyl engine:
ref trigger wheel 18-1, sync 1 event every 720°
i use mode 7 for other 4 cyl engine, with ref trigger wheel 24-2, working fine.
Because the OD is very small, not possible to cut 36 tooth, the owner
decide to choice 18....When we try to start the engine, no sync, sync error appear.
with mode 2 the engine want to start. Crip is ok, checked 2 time...sync sensor wiring etc
all looks ok. my last idea is: is that important to have 4,8,12,16,20,24,28,32,36 tooth?? 18/4=4,5
is that my mistake????
Thanks for any advice.
insomnia
Re: Ref Sync Issue
Postby IDP on Sat Oct 01, 2011 6:50 pm
18-1 is Mode 5, 1 missing twice/cycle
IDP
Re: Ref Sync Issue
Postby insomnia on Sat Oct 01, 2011 8:50 pm
Hi IDP,
you're right! i use mode 5 and not 7, i write wrong in my post...
insomnia
Re: Ref Sync Issue
Postby MarkMc on Fri Oct 07, 2011 4:50 pm
Have you got your edges correct? Does the ECU become synced with the spark plugs removed?
Re: Ref Sync Issue
Postby insomnia on Fri Dec 16, 2011 5:51 am
Hello Mark,
now it"s time to work on this old project. After your advice i remove the spark plugs
and the ECU work fine. Spark and injection are working, no sync or ref error.
Is the engine speed too low by cranking? and/or one missing tooth gap too small
on a trigger wheel with 50mm? Can i fix it if i use 18-2?
Thank you.
Francois
insomnia
Re: Ref Sync Issue
Postby Dragon on Fri Dec 16, 2011 12:02 pm
If you are making the trigger disc yourself, why do you have to use missing tooth?
I think 12 teeth should be fine for your application.
Dragon
Re: Ref Sync Issue
Postby MarkMc on Mon Dec 19, 2011 10:22 am
Send a ref sync capture for me to look at, one with the plugs in and one with them out. Also the current ECU configuration would be good.
When it comes to missing tooth modes (my preference) you need to understand that the cranking consistency and also cranking speed become very important. Generally I would not recommend 18-1 as it is a little low in the tooth count for a missing tooth mode but this really depends on the cranking speed. I would predict you need about 250rpm cranking speed (consistently) to make this work well.
Always look at what car manufacturers do for guidance generally 36-1 is the minimum although bike manufacturers use down to 24-2.
Users browsing this forum: No registered users and 30 guests
