Temp sensor issues
Temp sensor issues
Postby FoxPerformance on Fri Sep 16, 2011 1:52 pm
m600, using bosch 2500 ohm for air temp and engine temp.
both channels are configured in the ecu setup for Celcius, they read fine in the ecu editor screen monitor.
but when they are sent to the SDL they read about 26 degrees too high. and in the SDL config everything is setup for celcius too. on the display and I checked in the channel editor as well to make sure both channels default was set to celcius.
thanks for the help
Ben Fox
www.FOXPERFORMANCEENGINES.com
(719)570-9595
FoxPerformance
Re: Temp sensor issues
Postby MarkMc on Fri Sep 16, 2011 5:56 pm
Hi Ben,
Send your ECU and SDL configs to support@motec.com.au and I'll have a look.
