Synchro Rev
Synchro Rev
Postby lonestarrpm on Thu May 26, 2011 11:51 pm
I'm new to engine management computers -- but I'm a electrical engineer
that does basic programming all the time.
If I wanted to program the capabilities to do Synchro Rev
is it possible with an M48?
I figure I would need RPM count, Wheel Speed, and which gear was I in indicator,
clutch engagement switch, and a map of gear ratios.
Is this type of programming possible? Is there an upgrade that might make it possible?
thanks,
Mike
lonestarrpm
Re: Synchro Rev
Postby Holmz on Thu May 26, 2011 11:55 pm
And if you had brake pressure - then you would know when to do down shift rather than upshift.
Re: Synchro Rev
Postby lonestarrpm on Fri May 27, 2011 3:42 am
I'd even be ok with a button on the steering wheel to engage it.
That way both feet in wouldn't free rev the engine.
Mike
lonestarrpm
Users browsing this forum: Baidu [Spider] and 5 guests
