afr meter
afr meter
Postby hornet75 on Wed Feb 02, 2011 11:45 am
gday guys
would like some advice please,im looking at purchasing an AFR meter any particular types to look for or keep away from
hornet75
Re: afr meter
Postby OmarK on Wed Feb 02, 2011 12:54 pm
The upgrade in the ECU is the simplest option for reading Lambda but buying our PLM (Professional Lambda Meter) means you have an AFR meter with a display that is not tied to your car permanently. Alternatively if you are not looking for a standalone meter we have an LTC (Lambda to CAN) which allows you to view the lambda value on your laptop screen or a MoTeC dash or ECU via the CAN Bus.
OmarK
Re: afr meter
Postby hornet75 on Thu Feb 03, 2011 6:12 pm
thanks, yeah i do want to use it on more than one racecar,the ecu im tuning at the moment is a m48 what does it cost to get lambda upgrade
hornet75
Re: afr meter
Postby Holmz on Thu Feb 03, 2011 9:06 pm
hornet75 wrote:thanks, yeah i do want to use it on more than one racecar,the ecu im tuning at the moment is a m48 what does it cost to get lambda upgrade
Did you read Omar's post ^ ?
I would have thought that you would be asking about the LTC ...
Re: afr meter
Postby OmarK on Mon Feb 07, 2011 8:40 am
We sell our products through a network of dealers around the world. A list can be found on our website under sales>dealers.
OmarK
Return to Tuning discussions
