- Reanult flywheel tooths.jpg (75.88 KiB) Viewed 9524 times
Hello.
I have problems to configure my M4 on a cliosport group n car.
Its a special flywheel pattern, 60-1 + a long tooth, a tooth with no gap between 57-58.
I did see somebody else use ref/sync mode 81 and tooth ratio 50. I have to use sync mode 83, but the strange thing, if I use tooth ratio 50, I get a lot of sync errors and no signals out to coils, but my cranking rpm are normal. If I set tooth ratio to 80, something something start to happend. The ecu send out signals to coils and injectors, but when I watch my ignition lamp, its unevenly signals.
Is the flywheel pattern due to my problems?
Is it easier with a M400?
