Motec PLM - Narrowband 0-1 volt Output
Discussion and support for the MoTeC PLM and LTC's
Postby thedge on Thu Aug 16, 2012 8:03 am
Im trying to troubleshoot why my daily driver is bombing emissions testing. To do so, ive been looking at installing my PLM into it for a sanity check on the fuel ratios. Its not a modified car so it only has one O2 sensor bung. Thus to get valid numbers itll need a narrowband output from the PLM to the ECU so it doesnt run in open loop and skew the AFR.
Ive been through the PLM configuration utility but cant really make sense of the analog output screens to determine if I can get it to do a 0-1 volt simulated narrowband on the analog output.
Can anyone provide a config file or some screenshots showing how to configure it?
Thank you
thedge
Return to PLM & LTC
