View Device Config
View Device Config
Postby tcbandituk on Wed Jul 11, 2012 5:49 am
New to Motec so still learning the ropes.
Whenever I try to select View Device Config, I get the error below, any idea what's causing this ?
tcbandituk
Re: View Device Config
Postby JamieA on Mon Jul 16, 2012 10:58 am
do you have the latest i2 installed?
do you also have the latest version of the softwre it is trying to open also installed (assuming m84 ECU manager?)
-Jamie
JamieA
Postby tcbandituk on Mon Jul 30, 2012 6:32 am
Latest version of i2 installed and firmware is 1.10N
Tried reinstalling but still get the same......
tcbandituk
Postby tcbandituk on Mon Jul 30, 2012 7:04 am
Did a bit of rootling around on the PC (registry etc) before finally sussing it, it was fairly straight forward in the end. :roll:
Just need to go to the i2 properties- compatibility and change the privilege level to run it as an administrator :idea:
tcbandituk
Return to M84 ECUs
