NOT VIEWING DEVICE CONFIG
Postby astragsi on Sun Jul 08, 2012 4:53 pm
Recently upgraded my software and firmware to the .35,
from when i did this I can't use the "VIEW DEVICE CONFIG" in the I2.... this was a very usefull tool ..... I am sure you are aware of this problem can you please advise how to fix this.......
astragsi
Re: NOT VIEWING DEVICE CONFIG
Postby Scott@FP on Sun Jul 08, 2012 9:11 pm
It works on 3.5, you do have to have ECU Manager closed before you hit 'view device config' in I2. If ECU Manager is currently open it won't work and never has for me.
Scott@FP
Postby astragsi on Mon Jul 09, 2012 7:29 am
It does Not work when you upgrade the firmware, ECU Manager and I2 software to the latest sofware on the Motec Site... I know more peaple experiencing the same Problem, I am sure Motec knows about the Problem, Hope they get back to us to fix this problem as I used this tool a lot....
Yes the ECU Manager is closed infact Before when you have the ECU Manager open it will pop up and advise you to close it...
Now it says "ERROR OPENING FILE......... NO SUCH FILE ON DIRECTORY.....
Frustrating :(
astragsi
