Dashlogger CDL trackit
Postby Günther on Mon Jun 25, 2012 6:45 pm
Hello, does anyone find a bug in GPS Baecon insert Manually ??
I want set the Track GPS Points in my CDL1,31 software . But if you insert E ( East) it writres Later w ( west9.
and The systems doe s shit.( 54°52" 14.39" N/ 9° 16" 37.99 "E). ( Changes to:54°52" 14.39" N/ 9° 16" 37.99 "W)
Regards
Günther
Günther
Re: Dashlogger CDL trackit
Postby JamieA on Tue Jun 26, 2012 12:52 pm
I have always used and tested with Decimal degrees to enter the beacon location.
Although it should work in degrees minutes seconds mode, If you use decimal degrees, Im sure you will find that it works correctly
regards,
Jamie
JamieA
Return to ADL3, SDL3 and CDL3
