Shane,
Thanks very much for the information, very clever.
I will set this up on my engine.
Hugh
TunedByShaneT wrote:You can do this already to measure crank twist if you have the cam control upgrade on the ECU. I was asked to demonstrate this for a TF engine builder for the same reason.
Put a 4 tooth wheel on crank opposite end from ref sensor. Hook it to dig input set to cam position 8 tooth evenly spaced. Zero position at idle. Log cam position. Position reported in degrees is difference between front and rear of crank.
Holmz wrote:TunedByShaneT wrote:You can do this already to measure crank twist if you have the cam control upgrade on the ECU. I was asked to demonstrate this for a TF engine builder for the same reason.
Do you need the cam control upgrade to do that? or will they (m800) do that will out the control upgrade?
