M400 on CRB600 RR 2008
Postby harpera on Thu Jan 13, 2011 8:41 pm
I am having trouble with setting up the Crank and Sync Refs for this engine, i know the crank has 12 equally spaced teeth and the cam has 3 ofset teeth. Both are magnetic, can anyone give me a hand with the settings and possibly timings/ a map?
Mark Harper
Lancaster University Student Racing Team 2011
harpera
Re: M400 on CRB600 RR 2008
Postby OmarK on Tue Feb 08, 2011 9:00 am
To run this engine you need to use mode 22 which is specifically written to take into account the unusual sync teeth number and layout.
The settings should be:
Ref/Sync Mode = 22
Crank Ref Teeth = 12
Crank Index Position = 431
Ref Sensor Type = 2
Ref Sensor Edge Polarity = 1
Ref Sensor Trigger Voltage = 0.0
Sync Sensor Type = 2
Sync Sensor Edge Polarity = 0
Sync Trigger Voltage = 0.0
You need to check the CRIP and the sensor edges.
OmarK
Postby olie05 on Sat May 26, 2012 3:21 am
Can anyone confirm if these settings will work on an f4i?
Also, is there any documentation on how to set up Mode 22 that I can read?
olie05
Postby olie05 on Sat May 26, 2012 4:04 pm
I have confirmed that these setting do work for the F4i, since i was able to fire up the engine today.
I'll be checking timing with a light tomorrow, but I'm still curious as to how exactly mode 22 works.
Any info is appreciated. Thanks!
olie05
Users browsing this forum: No registered users and 28 guests
