Dave
ddahlgren wrote:Is there any fix for the IEX Denso verion dwell stretch from what is in the dwell table? Why can't I get what I ask for? Specifically a D585 AC Delco coil that will self discharge if dwelled wrong.
Dave
ddahlgren wrote:I have been told by Motec USA that the IEX adds dwell time beyond what is in the dwell table at engine speeds below 400 rpm. Some ignitions will self discharge if the dwell is too long to prevent them from burning up, the AC Delco D585 happens to be one of them though a very good in all other respects a very good inexpensive coil. I really don't want to run wasted spark and fire 2 coils at a time and eliminate the expander. I have an M800 but only 6 ignition outputs. That leaves me the choice of firing 2 coils at a time or use the IEX. I am not comfortable firing 2 coils at a time to be candid. It is a very expensive engine car combination with very few spare parts available if at all, Aston Martin 6 liter twin cam V8 in a vintage GTP car. I have not put a scope on the coil output of the IEX at cranking but will do this weekend. Since the change from distributor to coil near plug the car is very hard to start as it is kicking back on the starter from the coils self discharging. I am looking for a solution to theis 'feature'.
Dave
SprinterTRD wrote:Dwell extension is done by the ECU as well.
The length of the dwell ectension is to some extent dependant on the REF/SYNC mode.
The IEX can be modified to only give a 7.5ms dwell time however the timing is delayed during cranking so CRIP can only be done after the engine has started.
If you need the IEX modified you will need to return the IEX through a MoTeC dealer listed on the website.
