And maybe a dumb question.
But if that is a Motec ignition output signal. Why are there multiple signals then a gap. And why is there a much longer magnetic trace ?
It would seem more indicative of a crank/cam trigger trace of some sort ?
stevieturbo wrote:And the mag sensor wires should also be shielded.
hall sensor wiring is less important, but good practice to shield them.
But most important is routing them well away and never parallel to any high voltage wiring.
And as the MSD can trigger the coils at around 500v, these too should be considered high voltage as well as the actual HT leads themselves.
Despite this problem, does the engine run, and is ignition timing as commanded on the map tables ?
stevieturbo wrote:And maybe a dumb question.
stevieturbo wrote:You said the scope trace was of the Motec's ignition output to the MSD ?
But most of the scope traces look like a crank and cam trigger ?
stevieturbo wrote:It's obviously interference.
And you still havent answered any questions.
szabyk RST wrote:Holmz wrote:It is either electrical or magnetic.
Are you running a condenser?
Are all the ECU sensor wires run as twisted pairs?
the ref HALL
sync magnetic
no i not running condenser,and not twist the sensor pair...
Does the engine run ?
does it run normally ?
Is ignition timing as commanded ?
Does this interference actually cause a problem ?
SprinterTRD wrote:The noise is from the ignition system, move the timing around and you will find the noise will move as well.
Are you using resistive spark plugs? If not use them.
Are you using suppressed ignition leads? If not use them.
Users browsing this forum: Google [Bot] and 0 guests
