What is this?
Re: What is this?
Postby stevieturbo on Mon May 07, 2012 9:46 pm
And maybe a dumb question.
But if that is a Motec ignition output signal. Why are there multiple signals then a gap. And why is there a much longer magnetic trace ?
It would seem more indicative of a crank/cam trigger trace of some sort ?
stevieturbo
Re: What is this?
Postby szabyk RST on Mon May 07, 2012 10:20 pm
stevieturbo wrote:And the mag sensor wires should also be shielded.
hall sensor wiring is less important, but good practice to shield them.
But most important is routing them well away and never parallel to any high voltage wiring.
And as the MSD can trigger the coils at around 500v, these too should be considered high voltage as well as the actual HT leads themselves.
Despite this problem, does the engine run, and is ignition timing as commanded on the map tables ?
this car mapping now...this is a new project...but my old car is running same management... (M4 pro,MSD Dis4,MSD coil,same HT leads)
http://youtu.be/ldWdQ1XjKL8
http://youtu.be/BIzqAIvIgMA
the two trigger is doing shielded cable...
the MSD all wires running "away" from all other cables
szabyk RST
Re: What is this?
Postby szabyk RST on Mon May 07, 2012 11:09 pm
stevieturbo wrote:And maybe a dumb question.
this is two sensor.....the crank sensor 36-1(motec trigger) HALL GT101...(the left OEM the right from Motec drawing)
the cam trigger only 1 tooth OEM magnetic sensor (OEM the inlet cam)
szabyk RST
Re: What is this?
Postby stevieturbo on Tue May 08, 2012 9:36 am
You said the scope trace was of the Motec's ignition output to the MSD ?
But most of the scope traces look like a crank and cam trigger ?
stevieturbo
Re: What is this?
Postby szabyk RST on Tue May 08, 2012 4:49 pm
stevieturbo wrote:You said the scope trace was of the Motec's ignition output to the MSD ?
The input signal is the same...I think it is a central problem... :geek:
but what is it? :D
szabyk RST
Re: What is this?
Postby stevieturbo on Wed May 09, 2012 10:17 am
It's obviously interference.
And you still havent answered any questions.
Does the engine run ?
does it run normally ?
Is ignition timing as commanded ?
Does this interference actually cause a problem ?
stevieturbo
Re: What is this?
Postby SprinterTRD on Wed May 09, 2012 10:23 am
The noise is from the ignition system, move the timing around and you will find the noise will move as well.
Are you using resistive spark plugs? If not use them.
Are you using suppressed ignition leads? If not use them.
SprinterTRD
Re: What is this?
Postby Holmz on Wed May 09, 2012 12:54 pm
stevieturbo wrote:It's obviously interference.
He answered some of them.
szabyk RST wrote:
Holmz wrote:It is either electrical or magnetic.
Are you running a condenser?
Are all the ECU sensor wires run as twisted pairs?
the ref HALL
sync magnetic
no i not running condenser,and not twist the sensor pair... :?
I would take care of those before the resistive wires...
Holmz
Re: What is this?
Postby szabyk RST on Wed May 09, 2012 3:13 pm
the engine is run...but higher RPM misfire and MSD blink3
http://youtu.be/VMf_rcPd2rY
http://youtu.be/A_0ZVahq130
szabyk RST
Re: What is this?
Postby szabyk RST on Wed May 09, 2012 3:19 pm
SprinterTRD wrote:The noise is from the ignition system, move the timing around and you will find the noise will move as well.
i using same stuff as a last project..
szabyk RST
PreviousNext
