the motec no fault code...the MSD blinks 3 (Three Blinks: Intermittent input signal)
some pictures of the error:
thanks for any help
Holmz wrote:Where is that noise coming from?
That does not look helpful.
stevieturbo wrote:
And to confirm, this is a scope trace of the Motec's ignition output ?
If the engine is running, is ignition timing accurate ? Is all MSD coil wiring and HT wiring kept well clear of any crank/cam trigger wiring, and better still kept away from all sensor wiring ?
Holmz wrote:It is either electrical or magnetic.
Are you running a condenser?
Are all the ECU sensor wires run as twisted pairs?
szabyk RST wrote:Holmz wrote:It is either electrical or magnetic.
the ref HALL
sync magnetic
no i not running condenser,and not twist the sensor pair...
Holmz wrote:szabyk RST wrote:Holmz wrote:It is either electrical or magnetic.
the ref HALL
sync magnetic
Well...
1) Do you understand why you want to twist the wires?
2) Do you understand why to run a condenser.
I would do #1 first and then see where you are at. Then add the condenser and you will have some before and after examples to help you understand the effect of the twisting and condenser.
It would be augmented by understanding the reason why you do that, but just following the rules gets you to the same place.
