which mapper
which mapper
Postby tom-r33 on Sat May 05, 2012 3:40 am
Hi!
I have an M84 which i have wired in, got the car running and driveable with everything appearing to work as it should :shock:
I will be purchasing an SKM very soon and would need someone to set it up (i can wire it in) and map the engine properly
The engine is an RB25DET which is in a rear wheel drive skyline. It has a GT30 turbo and all the supporting modification required to produce around 500bhp.
Who would you guys say would be best to map this for me and why would you recommend them? (contact details appreciated!)
if anyone was wondering I was going to use the guy I purchased the ecu from, but after seeing what he was and wasn't doing I decided against it
Thanks in advance
Tom
tom-r33
Re: which mapper
Postby Sean on Sun May 06, 2012 2:25 pm
Normally helps to tell us where you are ;)
Sean
Re: which mapper
Postby Holmz on Sun May 06, 2012 6:17 pm
Sean wrote:Normally helps to tell us where you are ;)
As above.
What was the ECU guy doing or nor doing that gave you angst?
Holmz
Re: which mapper
Postby tom-r33 on Sun May 06, 2012 7:30 pm
ah! i'm in south west england, near bristol. i dont mind travelling up country for the right person
cheers
tom
tom-r33
Re: which mapper
Postby stevieturbo on Sun May 06, 2012 8:59 pm
tom-r33 wrote:ah! i'm in south west england, near bristol. i dont mind travelling up country for the right person
cheers
tom
Dave Rowe is generally regarded as one of the top Motec guys ( ex Motec )
http://www.epsmotorsport.com
or Richard at the Powerstation
http://www.powerstation.org.uk/index.asp
Or you could possibly try
http://www.enginetuner.co.uk/contact.htm
Not sure how familiar they are with Motec though. A phone call would soon tell.
stevieturbo
Re: which mapper
Postby Fast_Moto on Wed May 30, 2012 6:03 am
Tim Radley at http://www.racedevelopments.co.uk/ is really good.
Fast_Moto
Return to Tuning discussions
