Hooking up gear position to M400
Postby lawnmower on Mon Apr 30, 2012 2:12 am
I need to hook up the gear position to the ECU and would like to do this via an AT input and the voltage based gear detection.
I have 3 gears and each has its own soleniod so I have a seperate 12v volt feed for each gear. If I can regulate the voltage to the ECU from each solenoid it will recognise which gear is engaged right?
So can anyone tell me what I need (inline diode? etc. etc) to limit the voltage in each gear to set this up?
Thanks for your help.
lawnmower
Re: Hooking up gear position to M400
Postby lawnmower on Mon Apr 30, 2012 5:59 am
I have done some research and I think its resistors I am looking for?
lawnmower
Postby Holmz on Mon Apr 30, 2012 10:58 am
lawnmower wrote:I have done some research and I think its resistors I am looking for?
Maybe one of these if it can wrap around the gear shaft?
http://www.celesco.com/stringpots/?gclid=CJPw1Nah268CFQFKpgodHU2KEw
Holmz
Users browsing this forum: Baidu [Spider] and 54 guests
