Honda powered Daihatsu Charade Time Attack car
Postby alex on Fri Mar 16, 2012 9:57 am
http://www.youtube.com/watch?v=f5qCt2po ... AAAAAAAAAA
Short few laps of the car at Wakefield. Will post up some pics of the build.
If you build it he will come.
alex
Re: Honda powered Daihatsu Charade Time Attack car
Postby alex on Mon Apr 02, 2012 10:45 pm
So WTAC entry has been put in earlier today. This is where the car is at......and will now get the body widened for the event.
alex
Postby Pascal on Wed Apr 11, 2012 1:40 am
dear Alex,
no pics!! I would like to see it pretty please! Thanks!
Cheers!
Pascal
Postby alex on Wed Apr 11, 2012 4:19 pm
Pascal, no pics? As in no pics in the post i put up earlier or would you like more pics i.e interior and engine?
alex
Postby alex on Wed Apr 11, 2012 5:08 pm
Engine: Darton sleeved block(b18c), Erl 5 point main girdle, Manley 1000hp rods, Weisco pistons, CNC ported and chambered head, Supertech valvetrain kit with over sized valves. Adjustable cam pulleys. Garrett gt-3076 with Tial stainless v-band 0.63 rear housing and 60mm external waste gate.
Electronics: Motec m800 ecu, Motec 4ch CDI, Motec ADL8 dash, Motec PDM30. Selfmade body end ecu wiring harness(millspec, all heat shrunk and terminated)
Car has a standard 6 point cage, completely sealed rear cabin firewall for the cooling and fuel systems, tilton floor mount pedal assembly with brake bias adjuster knob. A fair bit of home made carbon work, front splitter diffuser, carbon window duscts for the radiator and carbon exit duct. V8 supercar rear wing. I am pretty pedantic with this car so all the work is pretty much top notch.
Suspension wise it has DMS 50mm three way adjustable coil overs with 750lb front and 650lb rear springs.
Brakes are Alcon 295mm rotors with HI-Spec 4 piston calipers. Rears are factory Daihatsu disc conversion from another model.
Gearbox is a Mfactory five speed pro series straight cut gearset and final drive. Plate type lsd. Custom billet axles on toyota outer c.v joints and honda inners.
alex
Return to Customer Projects
