M800 Does Not Communicate with MDC
Postby anthony_hk2001 on Tue Mar 20, 2012 9:41 am
As topic stated.
UPDATE: The M800 does not communicate with the MDC at all,
not getting data from MDC, nor getting Eff point from M800.
I have connected the MDC to the M800 in a CAN network
And inputs are set with ECU2.
CAN communication is set with CAN1 - M800 ECU Receive.
I also tried connecting the RS232 from the OEM hardness to the M800 ECU,
still does not get the data.
Can anyone help me figure this out?
Note: I can read data from MDC manager.
Thanks,
Best Regards,
Anthony
anthony_hk2001
Re: M800 Does Not Communicate with MDC
Postby MarkMc on Tue Mar 27, 2012 4:41 pm
Which EVO do you have? Only the EVO 10 communicates with the M800 via CAN, all older cars use RS232 only.
Can you email your M800 configuration to me along with the serial number of the ECU and MDC. mark.mccoy@motec.com.au.
Postby Scott@FP on Tue Mar 27, 2012 5:15 pm
And on the 9 and earlier models its a half-duplex situation, send from MDC to ECU only, the Tx from ECU is grounded.
Scott@FP
Postby anthony_hk2001 on Wed Mar 28, 2012 1:33 am
I will get the serial number later today and will send you the information ASAP.
Thanks,
Anthony
anthony_hk2001
Postby MarkMc on Fri Mar 30, 2012 1:58 pm
Just incase anyone else is interested: If you have a "Gold Box" ECU in your earlier that EVO10 EVO the comms to the MDC is a half duplex RS232, not CAN. You need to make a bit of a circuit to make it work, this circuit is what is in an OEM M800. See attached.
MDC comms connection.JPG (10.34 KiB) Viewed 11558 times
Postby Scott@FP on Sat Mar 31, 2012 11:06 am
Sorry I guess 'grounded' was a poor choice of words.
Once the half duplex circuit is set up, go to RS232 Setup, set Baud Rate 3841, data set to 6. Now all the MDC data will be available as "ECU2 XX" as listed in the MDC manual.
Scott@FP
