Ford 1.6L Twin Cam Engine - Not Sparking
Postby sasiganesh on Fri Mar 16, 2012 5:21 pm
The engine is synchronizing & the Injectors are firing but the coil is not igniting spark
The coil used is Bosch 0 221 503 485
Is the attached setup page is correct or if changes need to be done suggest
What is the dwell time for this coil
Ignition Setup.JPG (105.44 KiB) Viewed 11268 times
sasiganesh
Re: Ford 1.6L Twin Cam Engine - Not Sparking
Postby BMWTuner on Fri Mar 16, 2012 11:37 pm
Hi friend,
Are you sure that your ignition system is "rise trigger"? Normally is fall trigger in the most OEM system.. just check it, because if your charging is switch to ground, the wrong trigger can kill your ignition system due high dwell in high revs..
This coil in specific is usually used in Ford engines, correct? I never used this coil in specific..
But, i found the spec sheet for the 3x2-0 221 503 002 version (i believe that all hardware is the same, just more one output to work wasted in 6cyl).
Here you can see all data-sheet regarding current source and dwell times: http://www.bosch-motorsport.com/pdf/com ... ls/3x2.pdf
And like you can see, this ignition coil doesn´t include internal amplifier, so, you have to use external ignition module/amplifier. Motec cannot handle coil without amplifier direct.
I hope this help friend!
Regards!
Matheus
www.kolbercrank.com
BMWTuner
Postby super7 on Sat Mar 17, 2012 5:20 am
Hey.
I've driven with a dual module Borsch 0227 100 200 on my Zetec engine.
Ignition type 1
Number of coils 2
Sincerely, Nisse
super7
Postby sasiganesh on Mon Mar 19, 2012 10:53 pm
Thanks for the reply
As we are not in the position to change the Ignition coil
What is the best suitable External Ignition modulator for the Bosch Ignition coil 0221 503 485 to use with Motec M400
sasiganesh
Postby SprinterTRD on Tue Mar 20, 2012 8:40 am
If there is no module in the coil and you have wired it directly to the IGN output then there is a good chance you have damaged the ECU.
SprinterTRD
