Hi guys,
Has anyone built an ECU test rig for testing ECUs and sensors? I'm looking to build one and am looking for recommendations for a bench top PSU.
JR
Google autosim
20B wrote:Google autosim
Yes but I don't need to spend $1500 just to generate an rpm signal.
http://www.efi101.com/forum/viewtopic.php?t=6616&sid=66bb8d0162688fdbe9fc4a564dca31f3
Surely someone has used an Arduino to output a basic rpm signal to use before, anyone got some code they would like to share for it ?
AdamW wrote:I recently got myself a "jimstim" and find it to be a really helpful tool. Has pretty much all common ref/sync signals built in but also allows you to design a custom trigger pattern if needed and will also simulate any other sensors that you can think of at the same time, TPS, temps, 0-5v etc...
I think it was about USD80 for the fully assebled version that I got but you can get the DIY kit version cheaper.
