PLM serial cable & Can cable
Discussion and support for the MoTeC PLM and LTC's
Postby whrdnsx on Sun Feb 26, 2012 4:06 pm
I have a PLM connected to my M800 via a Can cable. As i have the PLM fitted into my console It's a pain have to remove a lot of interior parts to fit the serial cable to do an air calibration. Is it possible to fit my serial cable to the PLM & have the Can cable fitted into the serial cable so I can have easier access? The serial cable is about 2m long. will this effect anything? or maybe there's a Double adaptor available?
whrdnsx
Re: PLM serial cable & Can cable
Postby JamieA on Mon Feb 27, 2012 4:22 pm
you could have a single CAN connector with both Serial an CAN on it (using unused pins for the RS232 wires)
make up a patch loom with serial (in the D9) to serial (the rs232 pins on the round CAN connector)
the UTC has ony 3 wires connected to the round plug end, CAN Hi, CAN Lo and Gnd, so you should have 2 spares that you can freely use without any influence to the UTC.
regards,
Jamie
JamieA
Postby whrdnsx on Wed Feb 29, 2012 10:35 pm
Ok, thanks. will make something up.
whrdnsx
Return to PLM & LTC
